1984 Pontiac Trans AM (Black/Gold) Fender
Old 01-30-2015 | 01:12 AM
KnightRider499's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 V8 LG4
Transmission: Automatic 5 Speed
Quick question for you guys! So I have an 84 T/A in Black with the Gold trim. I am looking to replace the drivers side fender. It's pretty dented and has a good amount of surface rust. I got an estimate to fix it at ($604.00). I have tried to find a 84 fender, but I have had no luck. Can I buy a 1985 T/A fender and replace it with that one? And my other question is would it match well with my passenger side fender that is still in good shape or should I replace both fenders? Thanks for any help!
Old 01-30-2015 | 03:02 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1984 Pontiac Trans AM (Black/Gold) Fender
84 and 85 Have different P/Ns,I don't know what the difference is,so I would have to say NO,
Old 01-30-2015 | 12:59 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
No, it would not work because 82-84 and 85-92 were different fenders.
Try here: LINK
EDIT: The older fenders are more expensive, probably because less of them available/made, but even if you got both left & Right, you will still save about 60$ then having them repair the one.
Old 01-31-2015 | 12:49 AM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I never knew this, what is the difference between the two?
Old 01-31-2015 | 12:37 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
I've heard the vents are different sizes and the holes for the ground effects are in different places.
colton_carlson
03-08-2019 01:21 PM
I'llrocya
02-03-2016 12:43 AM
stalkier
12-07-2015 12:25 AM
johanlindgren
08-15-2015 09:37 AM
1992 Trans Am
08-08-2015 09:16 PM
Quick Reply: 1984 Pontiac Trans AM (Black/Gold) Fender
