Stock t/a 85-90 hood wont fully close
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Hey everyone i installed a hsr setup on my 88 gta and im finally putting my body panels back on and as i finished putting the hood on and tried closing it it doesnt want to fully close i dont wanna get a aftermarket hood it seems like it hits on the reenforcement brace of the hood i also replaced the motor mounts to poly ones is that a problem as well
Re: Stock t/a 85-90 hood wont fully close
HSR doesn't clear factory mounts either, the poly just exaggerates the problem. You stated you want to stay with the factory hood. Imo, just clearance the inner structure of the hood. Iirc, it hits in drivers rear and pass front (throttle body). On factory mounts a ball pen might get you enough clearance. If the clearance is real bad you may have to cut out and weld in new metal. Another option is to lower the engine down if there is room and check and adjust driveline angles. I personally would clearance the hood.
1 Post
Yea i have a spare hood that im gonna cut the bracing out snd try it if it closes ill do the same on the factory t/a hood and it should clear and close fully hopefully
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
