T top wearher strip channel
Old 01-14-2015 | 04:48 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well, like most of us . its time to replace the T top center bar and the weather stripping. my question is, is there a removable channel that the weather strip goes in? if so is it welded on ? screws? I cant seem to find this info and I need it BEFORE I start. I would like to avoid the cheep weather stripping and go for quality and exactness. so I need recomendations from members that have done this already. another question, were there really stainless T top bars?? if so ,the hunt is on for one of those as well. thanks
Old 01-14-2015 | 06:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: T top wearher strip channel
http://www.hawksthirdgenparts.com/ca...eel-t-top-bar/
Old 01-15-2015 | 02:34 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Wow! Thanks for the info!
Should I need to remove my t-top bar ever again, THAT thing is going in there.
Old 01-15-2015 | 06:54 AM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
If you just have rust on the ttop center bar, remove the bar and replace it with a new stainless one or a rust free used one. The t top channels are part of this center bar and will have nice new channels on a new piece. On the windshield channel and rear channel, they are spot welded on the car and repairing those can get expensive fast.
You will most likely find more rust when you take the weatherstripping out, so be prepared for it. I'm in the middle of repairing all of this right now, see my thread https://www.thirdgen.org/forums/body...eed-input.html
I got a replacement center bar, new weather stripping, and am having the body channels repaired by a local shop.
1992 Trans Am
05-10-2023 08:19 PM
83 Crossfire TA
01-03-2016 02:26 PM
angel2794
09-08-2015 07:22 PM
InfinityShade
09-05-2015 07:38 PM
FLAP
Camaros Wanted
09-02-2015 10:22 AM
Quick Reply: T top wearher strip channel
