Does anyone know what this is?
Car: 1988 and 1987 Trans Ams
Does anyone know what this plastic thing underneath my TA is?
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Does anyone know what this is?
It's just a skirt to hide the underneath of the car. A lot of these cars are missing them.
ah, so not for air flow or anything. Do you think anyone would want to buy these?
hmmm, ok. I'm going to see if I should really keep them or not....
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Keep Them!!!
They are Air Deflector Fences.
They are slightly warped, so they don't look very cool when looking under the car....
Engine: 5.0 EFI
Most of them looked warped if there not attached correctly,they straighten out when done right.
Ah, ok. I'm in the process of taking my ground fx off to replace the two front quarter panels... I'll try them on again when reassembling
I just got a pair off my 85 to put on my 86. But I forgot the correct way they should be installed . Are they installed so that they face the inside or outside of the car? I have them on now facing the outside and the screws line up fine. ( don't wanna look bad a car shows with them backwards)
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Facing outwards so you can't see the screws.
Car: 88GTA
Engine: 5.7TPI
What I did to mine, when they started to "look warped", was I took them off and placed them on a 2x4 lengthwise, covered them with a damp towel and took a, believe it or not, a steam iron on steam setting and ran it along them and pressed them back into shape. Then remount. Looks brand new!
