Can you swap taillights?
Old 12-15-2014 | 09:49 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
I have a '87 TA I'm working on. I just got a '84 roller for some parts I needed.
The 84 has some immaculate older style taillights that I prefer over the newer style ones. Can I swap my 87 taillights with the 84 taillights?
Thanks Guys!
Old 12-16-2014 | 08:10 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Can you swap taillights?
Did so on my 1990 T/A.
Works, though I seem to be the only one around whose filler panel won't fit 100%, so I ground some excess material off the trunk lock studs and it fits somewhat better since then.
Old 12-16-2014 | 10:30 AM
blktransam's Avatar
Sweet! Thanks for the help!
Old 12-16-2014 | 11:23 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
The GTA style grid lights are practically a direct swap for the 84's. If you have the base model lights with the separate amber turn signal, you need to do some wiring work to get it right.
Old 12-16-2014 | 05:35 PM
blktransam's Avatar
Have any of you guys used a knight rider tail light black-out kit by chance?
Old 12-17-2014 | 10:41 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Yep sure can had an 84' when I was 17 and swapped in a newer 85-90 style trans am tail light and it was a direct swap didn't have to grind or cut anything.
1992 Trans Am
05-10-2023 08:19 PM
E Rod
08-28-2015 06:17 AM
theshackle
08-22-2015 07:52 PM
Hello, Michael
08-20-2015 04:19 PM
355sbcTPI
08-19-2015 05:38 PM
Quick Reply: Can you swap taillights?
