headlights
Old 11-26-2014 | 08:54 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
headlights
wondering if any body
has done the headlight swap
for third gen i would love
some help on my car i want to swap
to bmw e36 headlights
Old 11-27-2014 | 06:14 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Several people have done it.
I would post links but I am on mobile.
Old 04-01-2015 | 08:33 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: headlights
There is a man who makes retrofitted projectors/halos/demon eyes for our cars specifically. Not a hack job, real projectors, fantastic light, and they look good too. He builds them to your specifications, and they are plug and play. Feel free to ask any questions!
Old 04-05-2015 | 08:01 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: headlights
Just did the 3 series swap today
Size:  229.5 KBName:  20150405_165614_zpsldyjlkru.jpg
Old 04-05-2015 | 09:40 PM
pasuperdave's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Axle/Gears: 10 bolt w/3.73
Re: headlights
how difficult is the 3 series swap?
Old 04-05-2015 | 09:53 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
Re: headlights
The hardest part is getting the low beams to stay on with the high beams, requires 4 relays, I ran out at 3 so I'm still not done, I'm also running power straight from battery to lights through the relays so there's no power loss through the old wiring.
The original harness plugs are just acting as switch signals for the relays.
Once you pull the old light buckets out, just need to pop new light housing in and take note of where the mount holes hit in the remaining bracket so you know where to drill for mount/adjustment screws. Angle adjustments are made by adding/removing washers from between the housing and bracket, which is a bit of a pain but it's a do it once and done thing so no biggie. There was a real good right up with diagrams I found on here a while ago and lost, I just sort of winged it. It can be done with mostly basic hand tools, with the exception of the drill.
Old 04-05-2015 | 10:46 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: headlights
Are those kits only for Camaros, or does he make them for Firebirds also? Specifically the '91-92 housings.
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
J. Chris Davis
Interior Parts Wanted
09-28-2015 12:55 PM
Quick Reply: headlights
