91 Trans Am GTA replacement ignition key?
I have lost the transmission key to my 91 Trans Am GTA. I have the door key. My questions is: if I would find out the right vat key code and order a blank key, would I be able to then use the door key to cut the ignition key - would that work? Basically I need to know if the door key is basically the ignition key without a chip in it. I hope I explained that well! I've been doing online searches, but haven't found a for sure answer.
Engine: 4++,350 & 305 CIs
Re: 91 Trans Am GTA replacement ignition key?
A good GM dealer will get you a key, if you have ID and proof you own the car.
Worst case, a lock smith or buy a new key and lock cyl combo.
I am going to call a dealership tomorrow. I was just wondering because I can order a key that is not cut, but has the right chip/code. I just didn't know if I could use that option if I didn't already have an ignition key to cut from.
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
for less than $100 you get a new ignition lock cylinder with a "template" key and a "chip" key ready to use... all you need is your VATS code.
here: http://www.ebay.com/itm/151252994590
i ordered 2 keys just in case
The ign key Cost me 5 bux at the dealership.
9192camaro
16
02-03-2019 12:21 AM
