who made these louvers
Car: 1988 iroc
Axle/Gears: 2.77
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: who made these louvers
Those look like factory louvers. There should be / should have been a hex-key, 1/4 turn, dzus-style, "screw" in each of the 6 holes around the perimeter. Good luck finding the mounting hardware if they were not included.
BTW, If you are in the Denver area I'll take the louvers off your hands.
I have the factory louvers on mine, those look the same. Should have plastic on the side slats, aluminum center pieces.
Car: 1987 Pontiac Firebird Standard
Engine: 2.8L V6
Transmission: Automatic
Yup, those are definitely factories. And I can tell from the pictures that you have more than enough hardware to mount them securely to your hatch. I have the same set on my car with only 4 out of the 8 hardware pieces and they are not going anywhere. Just take a rubber mallet to the clips when installing to really get them tight.
Nice find btw!
Nice find btw!
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
