Bumper mod?
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Bumper mod?
I haven't had the free time to sit down and actually look at it, but theroretically if you cut out the license plate mount on the front bumper, wouldn't it allow for more air flow and be more like a grill? Kind of like the duraflex gt bumper? I know this would be hard for some states like my own, tx, because we are required a front license plate but I'm willing to throw it in my windshield.
Re: Bumper mod?
i think you would need to remove or modify the crash bar behind the bumper cover for that to work? i could be wrong. you'll need to look at it.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Bumper mod?
The crash bar should be up high enough that it shouldn't be a problem. My concern is that you won't have anything supporting the middle of the lower lip/ground effects anymore and they will start to sag.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Bumper mod?
I've had this idea for years, wanting to completely open the grill, put a nice mesh near the rear. But there's no support for this huge opening. We'd have to add support somehow to keep the bumper from flopping at higher speeds.
Re: Bumper mod?
What about a billet grill that attaches at both the top and bottom of "hole". If it was sturdy enough it would act like a grill on anything else and theroretically keep anything from moving
Re: Bumper mod?
And I dont know, i'm getting pretty nervous about it just because of the front license plate requirement here , i really wish they would just go away with it already...
Car: 89' IROC-Z
Engine: LO3
Re: Bumper mod?
If I could get this center piece removed. I would have no problem whatsoever molding the plate flat into the base of the grill, maybe offset to the driver side opening flatspot.
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Bumper mod?
So how would you go about doing this mod? If I remember corectly a car that hawks third gen did had the whole thing removed exept for a little sliver that held a emblem on it. I have also thought about this for years. just never tried to do anythin more then just think about it.
Re: Bumper mod?
See I'm looking to get it completely off grill area. I'm looking for maximum airflow to my radiator. I'm just tying to think where in the world I could mold it that it would look half *** decent
Re: Bumper mod?
Re: Bumper mod?
Edit- nvm I just looked closer at that one... Now that I think of it, it really doesn't open up much airflow with that plate behind it. You'd have to go in and modify quite a bit of stuff. To achieve more airflow.
Re: Bumper mod?
I knew the nose was different, I was gonna upgrade to a low profile 85 bumper just to have the billet grille lol. But now I'm curious how much I can modify the stuff behind it to allow more air access
