Windshield wipers not moving far enough
Old 07-21-2014 | 05:44 PM
crystal383's Avatar
Trying to get my windshield wipers to work. The harness has been cut and messed with so I'm just running power straight to the yellow wire coming off the windshield wiper motor.
I pulled the cowl mesh off so I could see if the motor was turning. It was turning just fine. But it wasn't moving far enough. The wipers were only going a couple inches back and forth.
How do I get the blades to travel the correct distance?
Old 07-27-2014 | 01:06 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Windshield wipers not moving far enough
In the cowl, the long braces are slotted where it attached to the wiper crank.Turn the wipers on & shut off when they reach their max travel.Loosen the screws & adjust the travel.
There may be another issue though, since the harness is butchered.
codeysabatini
11-10-2015 05:07 PM
skinny z
10-05-2015 07:23 PM
drumstixer
09-29-2015 04:02 PM
adelane
09-09-2015 09:51 PM
Quick Reply: Windshield wipers not moving far enough
