Seam question.
Old 07-18-2014 | 03:23 PM
TheIgnitious's Avatar
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Seam question.
I'm been slowly but surely redoing the seam sealer on my car, but I'm having a problem narrowing down a current problem. I have a leak on my driver side kicker panel when it rains and it is leaving a small puddle of water on my floor and a leak there next to all those hot wires is obviously not a good thing. So would this be the cowl? Because since I've redone the wiring I can see a seam on the actual kicker panel (or whatever the metal piece behind panel is) up close to the firewall but I'm not sure where this is and if it's the problem.
Old 07-18-2014 | 04:47 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Seam question.
It's either the cowl or windshield. You can see the back of the kick panel if you take the fender off.
Old 07-18-2014 | 05:12 PM
Re: Seam question.
That's what I thought. I've noticed the vin number fogging up some days so idk if that would lead me to believe windshield.. But I have a brand new windshield with that black glue crap so I don't see how that would be possible
Old 07-19-2014 | 07:40 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Seam question.
the upper corners of the cowl are originally sealed with some sort of putty. after awhile it dries out creating a leak.this was where mine was leaking .maybe have a look at yours too?
Old 07-19-2014 | 07:45 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: 383-Holley Terminator EFI
Transmission: 700R4 Pro-Built Street/Strip kit
Axle/Gears: Strange S60 3.55:1
Re: Seam question.
You can use a foaming glass cleaner to check for leaks. Spray it around the windshield, then take a blow gun on the inside of the car and start blowing air around the perimeter of the glass. If there's a leak, you'll see a chunk of foam blow off the car. That will at least tell you if the glass needs to be resealed.
Not sure on our third gens, but newer cars, the A-pillar is a "wet area" and the water is meant to drain out through the rockers. In your quest to seal seams, you didn't seal the rockers, did you?
Old 07-19-2014 | 08:14 AM
stealtht/a's Avatar
Re: Seam question.
Water is not meant to drain from our a pillars. They are sealed at the bottom. In fact this often causes our a pillars to rot when water gets in from the roof.
Old 07-19-2014 | 09:49 AM
Re: Seam question.
By upper corners do you mean by the driver side windshield wiper? If so I know exactly where it is leaking cause I knocked off that putty one day
Old 07-20-2014 | 01:02 PM
Re: Seam question.
After tearing the fender and kicker panel off yesterday I believe water was running down onto the seam between the wheel well and the firewall. Redid and painted and I'm going to test it today to see what it does.
Old 07-20-2014 | 10:12 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Seam question.
ZZ3Astro
08-13-2019 01:57 AM
Rousseau92maro
02-01-2016 06:12 PM
jaridjohn
10-05-2015 08:01 AM
corey8084
09-17-2015 03:56 PM
Ian Irvine
09-04-2015 09:08 AM
Quick Reply: Seam question.
