Help Me Pick A Hood
Car: 1985 Z28 Camaro
Engine: 383 Stroker
Transmission: TH350
Help Me Pick A Hood
I know this has been discussed to death and I've searched and read the threads but I would like a fresh opinion on the subject. Putting a new hood on my 85z28 and want opinions. This will not be a daily driver. I have a 383 stroker in the car so I would like to pick some clearance. WIll a 2" cowl be enough? I'm not going to be drag racing the car so weight isnt really a primary concern. Fitment and low hassle are priorities. Thanks and let me know what you've got.
This is the intake I will be using http://www.summitracing.com/parts/sum-226010/overview/ with an Edlebrock air cleaner from Auto Zone 14" round not sure of the height exactly.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Help Me Pick A Hood
How tall of an intake and how big of an air cleaner are you running? After we know that then we can guide you as to how much hood clearance you will need.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
I have a goodmark steel cowl hood on mine.direct bolt on.only problem is its a little hard to see over.
Car: 1983 Z28
Engine: 385 Fastburn
I also have a goodmark 2" steel cowl hood, great fitment and an overall great product.
For reference my car is carb'd with a high-rise single-plane air gap intake and a 14x3" air cleaner(drop base)
Engine: 383 Stroker
Transmission: TH350
Thanks for the replies, I think I like the cervini 3" fiberglass really well. Seems to fit good from what I can figure and should be a decent weight savings, which never hurts.
Hotrodboba400
12-10-2019 07:07 PM
dbrochard
10-03-2015 12:43 PM
