Crashed my iroc (with pictures)
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Some lady pulled out without looking and I had almost no time to react, was going approx. 40mph when impact happened. Doors and t tops all fit perfect and open correctly still. The core support is bent back an inch or two, and the front frame horns(or whatever their called that the impact bar bolts to are destroyed and bent down significantly...
My question is, can I weld on new frame horns? I know I can do the core support, I've welded in new ones for Hondas and toyotas, many times, and done lots of panel realignment before, I'm very familiar with body work and such. I know I need a new core support, impact bar, frame horns, ds fender, inner bumper filler, bumper cover, parking lights, grill, fog lights, emblem, etc. I'm pretty sure I can collect 90% of this at my two local wrecking yards... But is anyone familiar with welding on those frame horns or core support? Where should I cut and also where should I take measurements to make sure the cars not bent in any unrepairable way. The car still drives perfectly straight and doesn't pull to one side or the other driving or braking. Any help is appreciated. I'm so heartbroken, i actually cried. I just had the front end repainted, restored with the decals and emblem a month ago... The car didn't even have a door ding and has a brand new engine spent $10,000 on. And new tranny a month ago. Besides the front end and a cracked dash the car was flawless...
Re: Crashed my iroc (with pictures)
Sorry to see this. Being it was someone pulling out in front of you, it should be their fault. I would go to the best body shop I could find, most likely a dealership if they'd take it on.
I had a VERY close call about a month out of paint. Idiot pulls out of a gas station right in front of me. All I could do was jam on the brakes and swerve into the second lane. I was to a complete stop and could do nothing more. I actually just covered my eyes with my hands in terror. Beat up Cherokee that looked seriously underinsured. Stopped 4 inches from my passenger fender. He got the worst bitching I'm sure he had in his life and I had to go home and collect my nerves for about an hour before the shaking stopped.
The aprons and frame horns will need to be looked at by a body shop that has a frame machine. Set-up and measure to see if it can be pulled or is too far gone for repair. The insurance co. will want to total it I'm sure but from what I can see, Body shops in the 80s and 90s fixed this stuff on a daily basis.
Whoop out all your receipts for paint, engine and anything else you have done with the car and watch em squirm. Defiantly let your insurance co. know what happened so they will have your back.
Sucks that this had to happen to one of the cleanest Third gens on here!
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
you don't have to let it be totaled, you have all your receipts? before the ins. person comes get them all in order showing how much you have invested, not just the motor. then look on-line and find cars that look to be in the same condition yours is/was in and get values.
it can be fixed!!
after ins.person comes,
you know the deal pull off all the front body panels, look to see where the damage ends, and get it on a frame machine and get it pulled out straight (to factory spec's)
then get your parts and put them on. ether way in-front of the strut towers line them up and weld and grind to look good, don't cover up bad welds with bondo! your going to have to do this part on your own or be at the shop daily. If you replace behind hind the strut towers I would suggest doing it at factory joints along the sub-frame. no-one will ever know if you do it wright. then before paint put in on the frame machine again.
Good luck
it can be fixed!!
Good luck
Car: 88 Formula, 85 Corvette, 90 GMC P/U
Engine: 305 TBI, 350 L98, 350 TBI
Transmission: 700R4, 4+3 man, 700R4
Axle/Gears: Stock
That is heartbreaking .... I would be I'll if that was my ride
1 Post
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
sorry to hear that man! hopefully everthing gets sitauted!
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
sorry to see this man, I agree, from first glance it don't look that bad, it can most likely be fixed just take your time and do it right.
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Have any pics of the car with the front clip removed after the wreck? I have a Firebird that had similar damage and I was able to pull the frame horns back straight
Car: Maros: 89 Z28 & 91 RS
Engine: 350 TBI & 305 TBI OEM
I´m so sorry, I had a similar crash, I totally understand your feeling!!! did air bag explode?
1 Post
Car: 1983 Z-28.. Owned since 1985
Engine: LG4 (H) Vin Code
So very sorry... I know a good therapist.
My expirence with body shops have been enlightening. I would never take my ride to a dealership body shop. Most likely the body man has never touched a 3rd Gen Camaro. (except in high school), and gets paid to do your car really fast, not good, just fast.
I would take my ride to a body shop that builds, and paints Muscle Cars/Hot Rods. Most of them except insurance claims.
Where ever you end up taking it, go around the back into the shop, and talk to the accual person that will be doing the work.
Linson
08-21-2015 02:12 PM
NufNuffZ28
08-14-2015 09:12 AM
mustangman65_79
08-11-2015 03:17 PM
