trying to make clear base model tail lights.
Old 03-20-2014 | 11:27 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
before you guys go all " noo dont rice it up" I DONT CARE.
now with that being said in my state i CAN NOT smoke or black out my tail lights i already got a 250 dollar fine for it. so my next option which i have consulted the inspection station is making all the colored parts on my base tail lights clear and puting colored bulbs in it . i have heard you can open trans am tail lights up and there are seperate colored lenses in side so it should be the same for these right. if anyone nice and kind can help it would be apreciated thank you.
Old 03-21-2014 | 08:23 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: trying to make clear base model tail lights.
Your inspection station should have told you you can't completely white them either. You have to leave the red reflectors as well, not just about lights. You can red out the yellow parts as yellow rear signals are not required in us and no one will notice, although technically ANY modifications to your lights is illegal under fed law.
Old 03-21-2014 | 09:50 AM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
There is not really anyway to "clear" the turn signal lense for base tail lights. Unlike ta lights, base tail lights are two red lenses and a yellow lense pressed Into a housing while ta lights are all red with a black design painted over. If you want to modify your lights to change the look I would recommend doing the amber delete.
Old 03-21-2014 | 04:33 PM
mikey8494's Avatar
Axle/Gears: stock
that makes it look alot better but trust me the police here just are *** holes they all know black out and smoked is not stock but they wont know if the signals are amber or not
how do you do that btw
Old 03-21-2014 | 05:47 PM
Eric-86sc's Avatar
Engine: 305, 355
Pretty easy, take the tail light housing apart and paint the amber lense from the inside and outside with testors translucent red paint. You should get away with this as the light shining through is not dimmed. Plus many cars have factory red turn signals.
Old 03-21-2014 | 08:16 PM
mikey8494's Avatar
Axle/Gears: stock
yea like my dodge noen also has anyone ever painted the black parts of the tail lights the same color as the car
Frozer!!!
01-19-2024 05:55 PM
Vintageracer
01-10-2020 06:33 PM
LittleFranks
08-20-2015 04:55 PM
Fronzizzle
08-19-2015 02:36 PM
Fronzizzle
08-09-2015 02:15 PM
Quick Reply: trying to make clear base model tail lights.
