T-top outer drip seal replacement
Car: 1988 iroc-z
Engine: 350 5.7L Tpi
Transmission: 700R-4
i bought new aftermarket t-top outer drip seals for my 88 iroc and i am trying to replace them and i need help ...not sure on how to get everything off to even get to the drip seals ....i removed the lock handle and plastic piece and thats as far as i got... please help thanks
Car: 1984 T/A
Engine: LQ4
Re: T-top outer drip seal replacement
the rubber weatherstripping sits inside of a rail. depending on how much adhesive is in it you should be able to slide or pull the rubber out. after that unscrew the "rail" for the rubber and you should be able to pull off the drip seal. mine was held in with double sided tape. good luck.
ambainb
04-25-2016 09:21 PM
