Bracing a T-top car before mointing in rotisserie
Old 01-27-2014 | 08:38 PM
jfl1960's Avatar
OK I have a1982 Z28 T-top car and have decided to build either a full rotisserie or a tilt-jig to do the bottom of my car, just had rotator cuff surgery and have limited use of my right arm for at least a year so working under the car on stands is definitely out of the question, anyway my concern is twisting the body of a t-top car, I have seen quite a few 3rd gen's in rotisseries and none of them have been braced however they have all been hardtops furthermore I have also seen warnings to make sure a t-top is braced, so to err on the side of caution I have decided to add some braces to maintain the body alignment. Now to my question, I am looking for advice on the proper way to brace the chassis to prevent twisting while in the tilt jig or rotisserie, hoping someone out there has done this with a t-top and is willing to share their successes or failures(I learn from mistakes as well as successes), any suggestions or pictures would be greatly appreciated, thanks.
Old 01-27-2014 | 10:17 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Bracing a T-top car before mointing in rotisserie
I always weld a bar from the front door jamb near the windshild to the rear of the door jamb at the top
Old 01-28-2014 | 10:25 AM
jfl1960's Avatar
Thanks for the input, do you put any cross bracing in the body or just across the door openings, would love to see a pic of a braced t-top in a rotisserie.
Old 01-29-2014 | 05:49 PM
Engine: LQ4 ls 6.0
I don't have any photos but if you need more bracing you can weld a brace on the bottom of the roof at the outer side of the t top were the door glass meets the t top
Old 01-29-2014 | 08:51 PM
jfl1960's Avatar
Here's a video of a Trans Am getting a floorpan, check out the brace in the doorway, that was what I had imagined on the doorway of my z28 for starters.
1992 Trans Am
05-10-2023 08:19 PM
IROCZ1989
01-24-2016 04:55 PM
Linson
08-21-2015 03:12 PM
3rdgenparts
08-06-2015 10:03 AM
NBrehm
08-05-2015 08:57 PM
Quick Reply: Bracing a T-top car before mointing in rotisserie
