90-92 GTA bumper question
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: 90-92 GTA bumper question
On 91-92, the gfx is part of the bumper. Therefore, different front bumper cover for gfx and non gfx cars. There is also a fender part behind the bumper cover, but it's different from 85-90 cars.
The first car has ground effects along the body, so it has ground effects built into the bumper cover as well. The second picture is too dark to see fir sure, but it looks like it does not have ground effects so the bumper cover doesn't have ground effects either.
Also:
You sure yours is a Gta? Doesn't look like it has gfx or vented hood or wraparound rear wing.
Also:
tsev, please post your VIN so I can run it through compnine.com to check and see if your car is a real GTA.
Looking at the photo of your car, you are missing the GTA wheels, rear spoiler, front bumper, and fender ground effects. The side mirrors look to be aftermarket, and it appears that your car has the front bumper and possibly fenders from either a Formula, or a non-W68 aero package base model Firebird.
I know that rear spoiler and wheels have been taken off by the previous owner, dont know the reason. Side mirrors are original for export market.
The bumper seems to be GTA but does not have lip. Does this mean that GTA bumpers could originally be ordered with and without fgx when new?
Here are more pics of the car, what about hood, is it GTA?
No, they didn't cut it off, they just used the non gfx nose because that's all they could find. It's even difficult to find those here.
What about fenders, as you can see on the pic I also dont have gfx under both front fenders. Is fender gfx also part of fender just like bumper or it is separate piece that can be bought and attached?
I've never seen that front fascia without the ground effects lip. I was always under the impression that the Formula and the base Firebird without the ground effects package got this fascia with the black grills and without fog lamps:
Apparently there were 3 styles of the '91 - '92 front fascias made.
These are the fender ground effect pieces you would need IF you had the correct front fascia:
http://www.hawksthirdgenparts.com/pr...-Per-Each.html
Yes, I am replacing this bumper with the correct one that has gfx.. I dont have to replace fenders, I just get the fender effects and mount it, right?
Interestingly enough, there are no RPO's for export shown on compnine, and it even shows the D81 aero spoiler. I guess it was converted for export before it was shipped out.
Wow, good point. I just assumed the mirrors were aftermarket, or maybe he hunted down a pair of super early '87 GTA or export mirrors. That also explains the taillights.
Can you please give me complete list from compnine? Thanks
Correction, export RPO is present now that I'm looking at it again. The code for it is "EXP". I'm using to seeing the Z49 export code for Corvettes, so I didn't know what I was looking for.
Thanks once again for the report
