Functional L88 hood
Functional L88 hood
Anyone know where I can buy/purchuse an functional L88 hood like the one pictured below??
Thats "ihateallmustangs" Camaro by the way.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
un4givin89
As far as i know nobody makes that hood, and from the picture it looks like it was grafted on to the stock flat hood, evidenced by the lines on the outside edge of the scoop, you can pick up one of those scoops for about $100 and either graft it on yourself, (really not that hard) or have a body shop do it.
I put the same scoop on my old 87 sport coupe, but there werent any seams, blended perfectly, so if you hve any questions about where to find that scoop or ho to do it get a hold of me..
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
No Cat, Dynomax Headers & catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims.
406 siamesed TPI in progress
87 IROC-z 305 TPI
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
that one was just grafted on to a regular hood it would seem, but vfn makes a glass l88 hood for thirdgen camaros. I'm considering it for my iroc.
try jc whitney, they sell a complete hood [no grafting] its like $398.
i think i did a dam good job considering im an amature at body work and the guy only wanted 20 dollars for the L88 scoop.
Car: RS
Transmission: 5 speed
I'm puttin an L88 on my hood. My buddie owns a body job out in ND and he and I are going to first fiberglass the underside, and add some support with specially made metal brackets. Then we are going to cut a hole out of the hood and put it in from the underside of the hood. Then we rivet it to the hood and mud the sides to make it one solid peice. When we finally get it done he says it will be pretty sturdy, if it cracks he said he do another one for me for free. So when I get it on I'll post pics but that's down the road a bit.
