What the hell is this piece called and where can i buy one?
The part that I have circled there. What is it called, who sells it? Need a good one, mine has a crack.... Id call it a rocker but a rocker really is the plastic piece along the end of the floor board inside the door....
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Re: What the hell is this piece called and where can i buy one?
You'll have to look for a used piece, or fix what you've got...IIRC, the only part of that factory body kit that is currently available are the lower front fender pieces (which just became available again a few years ago).
That door piece seems to be broken on about half of the cars I've seen, including mine when I bought it. Usually a passenger gets out of the car, opens the door on a low curb, and then puts a nice hole in it. I ended up finding the best one I could (which was still cracked), and fiberglassing it back together.
1 Post
Car: 1991 GTA
Engine: LB9
You are going to be on the hunt for a complete used one, or repair the one you have.
I ended up buying two broken ones to end up with one good one after some creative repair work.
Car: 92 Camaro
Transmission: 5spd
Axle/Gears: Stock
Check your local pick n pull or pull a part whatever it's called where you live, maybe ebay or something. I went through this on a different type of car and it was a pain. a camaro should'nt be as bad maybe even check the classifieds on here they will probably have one
That part comes in 2 pieces. Which one do you need? The part that attaches directly to the door or the rocker panel?
http://www.ebay.com/itm/91-92-Firebird-Trans-am-gta-passenger-side-door-ground-effect-with-bracke-/181261673447?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a3409a3e7&vxp=mtr
http://www.ebay.com/itm/FIREBIRD-ROCKER-GROUND-EFFECT-1992-1991-PONTIAC-RH-/370237294389?pt=Motors_Car_Truck_Parts_Accessories&hash=item5633dcc735&vxp=mtr
ambainb
04-25-2016 09:21 PM
mhatfield 14
10-24-2015 07:48 AM
