Am I out of luck with these fender vents?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Am I out of luck with these fender vents?
Even if you don't have the tabs, you can make tabs from the special plastic repair compounds, 3m or SEM.
or , much easier, a few tabs of 3M emblem and trim adhesive will hold it in just fine.
Just to be clear I was suggesting the 3m glue, not the tape. glue holds anything, same as what you would use for the bumper moldings down the side.
Pac J
05-17-2020 10:44 AM
