85 T/A Aerowing - refinishing
Old 01-17-2014 | 11:10 AM
ejscarfo's Avatar
My wing has a nice crack in the center of it. It looks like the PO tried to fill the crack with spot glazing putty, you know, that red stuff. Well it's starting to fall out. I haven't found a used fiberglass wing yet (it's like $600 for a new one with shipping) and because I do have experience with paint and body, I figured I could just refinish this original wing. Then I remembered, its rubber. Someone definitely painted it in the past tho, probably to cover the red putty. Now the paint is cracking on the flat top surface, not to mention that crack in the center.
So here's my question. What can I use to repair that crack and fill it in? I'm sure I can get the old paint off with some airplane stripper or something on that order. They sell the textured paint, so I can give it back the original textured finish. I just don't want the crack opening up again after its refinished.
Anyone have any tips?
Old 01-17-2014 | 02:08 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: 85 T/A Aerowing - refinishing
You dont want to use aircraft stripper it will melt the rubber I would sand it down to the rubber with 180 grit sand paper then clean it with some plastic cleaner then use some bumper repair it will flex and not crack then sand that down flat with 180 then apply some flexible primer
Old 01-17-2014 | 02:15 PM
ejscarfo's Avatar
Is there a bumper repair kit you'd recommend?
Old 01-17-2014 | 02:58 PM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
Lord Fusor 141/140 works real well on these wings
Old 01-17-2014 | 03:21 PM
ejscarfo's Avatar
I thought that stuff was an adhesive tho? Will it remain flexible?
Old 01-17-2014 | 05:51 PM
Engine: LQ4 ls 6.0
there are all kinds I use 3M but you have to have a special gun for that if you dont have a gun you can use ureathane supply http://www.urethanesupply.com/step3e.php that you mix up like a 2 part epoxy all the others require a gun
Old 01-17-2014 | 05:59 PM
ejscarfo's Avatar
Looks like that will do the trick. Thanks!
I will probably take the spoiler off and refinish it in the house now the weather is cold here in NY. I may just document the process and post the results...if I remember
Old 01-17-2014 | 09:08 PM
Engine: LQ4 ls 6.0
yeah photos would be cool and its cold here to 19 tonight
Old 01-17-2014 | 09:26 PM
ejscarfo's Avatar
It's in the low 40's here, but I hear it's gonna get cold next week. It figures too. I need to get the heater core done and it's been way too cold to work outside and my garage has my C4 still in pieces. How I miss summer.
Old 01-17-2014 | 10:13 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Just to warn you, your spoiler has a metal frame under the rubber. They rust and expand which pushes on the rubber forcing it to split. Even if you manage a decent looking repair with the the bumper repair material, it will keep forcing the rubber out and you'll have the same problem again later.
Old 01-17-2014 | 11:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I
Old 01-18-2014 | 10:33 AM
ejscarfo's Avatar
I'm sure it won't last, but I'd like to try. There are other things I'd rather spend money on restoring this car than the spoiler. I priced the fiberglass ones and with shipping, the cost is over $600. Add $100 for paint along with my time to prep and finish and it's an easy $1000 job. If I get a year out of the repair, I'd be happy.
The wife wants one trophy this upcoming show season. Cosmetically, the spoiler needs to be addressed as well as replacing some peeled striping. With a buff and the "new" used seats coming, this car is a definite show winner. You just don't see these third gen T/A's here on Long Island anymore. Like my 85 C4, I'm sure it will be the only one at the local shows.
Old 01-18-2014 | 10:53 AM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
With plastic you need to use adhesion promoter to open up the pores so the bumper repair material sticks. Im curious if the rubber will work the same way or not, let us know if you try it.
Otherwise you could go with one of the straight across spoilers. Those are easier to find in good shape and came stock in 85 anyways if I remember correctly.
Old 01-18-2014 | 10:59 AM
ejscarfo's Avatar
The straight across spoiler is my last resort. The car came with the aero package (wing & wheels) and I'd like to keep the look. My buddy has one of those spoilers in his garage I can have if I want it.
I know 3M makes a bumper repair kit that stays flexible. I may call my contact there and see if it will work on the spoiler. I plan to document this repair so stay posted.
Old 01-18-2014 | 06:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
If the crack is in the center you may want to try 3m weatherstripping adhesive.
do you have a pic??
F-body-fan
11-04-2015 07:13 AM
2012sergen11
10-13-2015 08:38 PM
Aaronv808
Members Firebirds
09-30-2015 01:55 PM
F-body-fan
09-23-2015 07:36 AM
F-body-fan
09-19-2015 10:02 PM
