Trunk Hood Pins
Old 01-12-2014 | 07:32 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Trunk Hood Pins
So i saw someone that used hood pins for their trunk, and i'm curious if anyone on here has any knowledge or wisdom about this. I know there are locking hood pins, and that would solve the issue and remove the weight of my faulty trunk latch system, but what would the best approach to this? any wisdom TGO?
Old 01-15-2014 | 02:56 PM
kennyjames's Avatar
Re: Trunk Hood Pins
The APC ones are actually not bad, very similar to sparco's
Old 01-15-2014 | 03:19 PM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Re: Trunk Hood Pins
I have thought of doing the same thing to get rid of the latch assembly. Locating them correctly is the hard part. Once you have the posts positions, you can use paint to help locate where you need to drill on the read deck. Obviously, measure carefully before the drill bits come into play.
manualbrakes.com
Brakes
63
04-09-2024 12:55 PM
Hotrodboba400
12-10-2019 08:07 PM
blackandblue02
09-10-2015 09:19 PM
sylentnite
09-09-2015 03:55 PM
Hotrodboba400
09-02-2015 08:28 PM
