What's The Fastest, Easiest, Cheapest Way To Fix Sagging Door Problem... PLEASE HELP!
We just got the door from the firebird on my camaro. All needed now is the holes filled from the ground effects and new ones drilled for mine. Then bolt them on. My dad is REALLY mad though. We just spent the past 2 days taking doors off and finally getting this one on without taking the fender off. Now we have the dreaded "Sagging Door Problem" I knew the bird had it but he is still mad. I just want to know what is the quickest way to fix this and will it hold up? Is there a way to tell whether it's the upper or lower hinge because I'll do that if it helps me get the solution. Thanks!
'91 Camaro RS 3.1L V6
4th Gen Seats, Sony Xplod CD Player, DJ Sexay's Kicks Panels with a Polk Audio 6½" Comp Set, 2 RF Punch 12's, RF Punch Amp 100.2, Coustic 360W Amp.
Soon to come, New Rims, New Rear Tires, Paint Job, Interior Color Change.
http://www.geocities.com/adidaspredator21/index.html
**BUT FIRST... gotta fix this... stupid people..**
Car: 87 IROC-Z
Transmission: automatic
I "fixed" my sagging door on a 1966 dodge charger i had by sticking washers between the lower door hinge and the door. They act as spacers and raise the bottom of the door. It's definitely the cheapest and easiest way to fix it. not exactly the right way to fix it, but it did work. Haven't tried it on a camaro door.
1987 IROC
305 tpi
g92
auto
39,000 actual
1987 IROC
305 tpi
g92
auto
39,000 actual
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have finally solved the sagging door problem on all third gen cars.I have developed a replacement UPPER hinge repair kit that will permanently repair this problem.The upper hinge is the real problem with sagging doors.Many owners think that this "sagging door problem" can be corrected by replacing the LOWER hinge pin & bushings.But after this has been done,the door can still be moved up and down.
This is a chronic problem that effects,or will effect every third gen car.
For more details go to www.3rdgensolutions.com it might be helpful.
Thanx,ANDYZ28
Thanx,ANDYZ28
Car: 1982 Z-28
$62.40 for one door. 2hours or so to do the job. Or $57.19 for GM part# 12392848(upper hinge assy.),remove the door completely from the car.Lay it on a bench of some kind,cut the old hinge off.Drill new holes,and install the new hinge assy.
I have already changed two UPPER hinges.I won't do it again.Each one took me a whole weekend.And the doors still did not fit right.The original hinges had three bolt holes to attach the hinge to the body.The GM replacement hinges had only two holes.You have to figue out where to drill the third hole(the third hole locates the door precisely on the body so the door will close properly)by yourself.It really is quite a project.Before I did it myself.I went to several body shops,they wanted in the $300.00+ range per door plus parts to do the job.
This is the whole reason I developed a replacement pin & bushing set.It's quick and easy.Without all the hassle of puuling the door of,cutting,drilling,etc.
I have an "installed"photo on my website.
Thanx,ANDYZ28
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Thanx,ANDYZ28
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
come on guys, i just looked at this website, the pass side door on my 86 camaro is perfect!, the driverside is a pain in the butt, it sags scrapes my ground effects and the fender took the paint right off, takes 2-3 times to close the door and it's just annoying, 62.40 for the kit isnt bad, consider buying the gm hinges, then the labor to remove the old hinge and drill and install this, seems much easier, and i plan on purchasing one for my driver side door. looks good andy!
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
