Door Trims and Moldings
Hi everybody! I'm trying to replace weatherstrips and everything that goes around them but I cannot find the part numbers or the names of all the moldings and trims on the interior and exterior. My car does not have t-tops. Does anyone have any idea what they are called and where I can find the replacements? Thanks a lot!
Re: Door Trims and Moldings
Am I understanding you want the channels that the moldings go into? Those would be only available used. There are plenty of companies making new weatherstripping kits. Best deal is to buy the whole kit at once. Piece it out and it will cost more. I used Soffseal on my car.
The drip rail is a separate piece than the channel the weatherstripping is set in. It can be adjusted once you remove the channel. It's screwed in the body under the channel. However, the channel is applied with a wide double stick tape that makes it tough to get off without damaging it. Need to take your time and be careful.
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
