Help removing fenders
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Long story short. I launched without my hood pins.Folded the hood and damaged both fenders.I did some searching on here but couldn't find any info on removing the fenders.Can anyone point me to the right spot?
Re: Help removing fenders
letss seeee...
id start with removing the front bumper, there are clips and bolts in the top that mounts it and the headlight bar to the core suport, under the front there are clips that attatch the valance to the core, then bolts along the bumper where it meets the fenders, unplug all your lights, basically comes right off
remove the hood, remove bolts along the top of the fenders, look in front of the front wheels under the car there may be a bracket bolted to the bottom of the fender, remove it, there is 1-2 bolts at the bottom of the fender behind the front wheels, (if you have side skirts they must come off) and unplug the marker lights and they are off, not to big of a deal, looking at the car its like a puzzle but easy to figure out, grab your tools and start with the side skirts or bumper, altho i didnt take pictures when i had mine all apart.
Car: 1985 Z28
Thanks for the tips. I've almost got them off at this point.
2 bolts under fender behind wheel, 2 screws under the rocker emblem, 5 nuts on the front of the fender mounting to the bumper cover, 3 nuts on the bracket that mounts chin spoiler( studs often break, be careful, just need them loose enough to slide out spoiler), 1 bolt for the brace to the frame under front of fender, 1 push pin on chin spoiler. Then all the bolts on top of fender. Pretty sure that's all of them. you don't need to take off the nose.
morrow
01-13-2024 12:29 PM
