Ram air hood help
Car: Black 1991 Pontiac Trans Am GTA
Engine: 350 5.7L V8
Transmission: Monster Trans 700r4
Ram air hood help
I have the ram air hood from hawks on my 91 firebird and I want to put it on my 91 gta but it doesn't latch properly or line up properly on the firebird right now and I don't want that problem with my gta, Its hard to actually close and once it latches shut it doesn't wanna open. Its also high above the headlights. Does anyone else with this hood have this problem and if so how would I fix it. I love the way it looks just don't like the functionality. Thank you
Re: Ram air hood help
You can heat it and conform it to where it needs to be a little better. It the easiest thing you can do that I did is get some hood pins. Or it would look cheesy and bad but you could take some metal Starla's and screw it to the underside of the hood to conform it to where you want it
Engine: 350 5.7L V8
I would post pictures but honestly I have no idea how it has a gap between the headlight and hood above the lights and the bottom corners sit lower the the body lines. If I remove the latch is there any way to hold it down besides hood pins
With a ratchet strap or somthing but I don't think that would looks to pretty. But with mine I had a big gap from the headlights to to hood and the hood sat a lot higher, so I adjusted my hood so it slid down towards the front of my car more and used the hood pins to pull it down. You said your headlights and front corners of your hood are lower than the fenders though?
Engine: 4++,350 & 305 CIs
Do a search here or on google, this has been covered many times.
These hoods "bolt on" but need adjustment to fit properly.
You could also ask a body shop.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Did you try adjusting the hood bumpers?
Sides of hood usually needs trimmed around the bumpers as well.
Panel alignment is tedious work, and any car that is this old and is getting panels changed will need alignment work.
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
The problem I ran into with mine when I had that car is I just flat out ran out of factory forward adjustment. I think that's fairly common and it was a lot of trial and error and patience to get it right
Engine: 350 5.7L V8
You probably have to take a dremel and open up the slots in the factory hinges to get it to sit right. I bet it looks something like this
Attachment 269051
Attachment 269052
Attachment 269051
Attachment 269052
Car: 91 Trans Am
Engine: 355 TPI
I have no idea but I dont expect it to be a high amount. Its just a matter of removing the hood, opening the slots up and aligning it
Engine: 350 5.7L V8
okay thank you I appreciate all the answers I had no idea what to do with the hood. Now its just a matter of hood pins I have no idea how to use em I never worked with them before but ill figure it out im sure
Car: 91 Trans Am
Engine: 355 TPI
Engine: 350 5.7L V8
Car: 91 Trans Am
Engine: 355 TPI
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Attachment 269051
Attachment 269052
Attachment 269051
Attachment 269052
Car: 91 Trans Am
Engine: 355 TPI
1992 Trans Am
05-10-2023 08:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
08-24-2015 07:52 AM
