Locked keys inside car, DOH!
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
So I had a moment of mental lapse, and locked my keys inside my car.. Heres my question, how could I get the door/ rear hatch open? It has manual locks, so they are the horizontal kind. also, the rear hatch has about an inch or two gap in weatherstripping thats not touching right in front of the little latch that locks it shut, and I can put a finger in and touch the latch mechanism. I really dont want to get a locksmith, as they charge more since i live on a military base. The Military Police are lame and dont carry slim jims like regular police, so no luck there. Thanks!
Re: Locked keys inside car, DOH!
Have a hatch release button? You can gently pull the window out and flip it with a broom handle. wrecker services have an air bag that inflates between the window and the gasket at the roof line to do this.
Car: 1991 Camaro RS
Engine: 5.0 L03
Like a giant portion of these cars, my power release isnt functional
I told my wife the car never spends the night outside after I locked my keys in the car. I literally opened the door with a ruler! Just pull back the window molding at the corner of the door. Visualize the lock cylinder rod position and push down. That simple It is that scary!
Car: 1991 Camaro RS
Engine: 5.0 L03
How is the lock cylinder positioned? and how would that work?
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Slim-Jim's work great on these cars. I don't know why you think they don't.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Good ideas, but it's probably not helping the rest of us by broadcasting to the world clearly detailed instructions on how easy it is to break into our cars.
If that scares you, you would be terrified on how easy they are to start up and drive off once you're in. NOT going to post that, just let me say it's unwise to park on the road like badtennant said.
Engine: V6, V8
Ignorance is bliss can be taken a different way sometimes.
Carry on, I see that he could just as well have Googled the topic and found a bunch of threads on the subject.
http://lmgtfy.com/?q=locked+keys+in+car+thirdgen
Car: 91 Z28 Coupe
Its amazing how much the windows can flex. I broke into mine with a door stop and stick from a tree Took about 30 seconds, if that. And i'm not a pro.
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I used a ruler, straight down beside the lock cylinder. Took me a while to get it. Once I did it the first time, I can get it opened in less than 5 minutes every time now. I was amazed at how easy it really was. I also used a paint stir stick, worked great.
Engine: 355
When this happened to me I started a thread here looking for advice, here is the thread, hope it help you out.
https://www.thirdgen.org/forums/tech...lp-me-get.html
1992 Trans Am
05-10-2023 07:19 PM
