Camaro doors on Firebird
I have an 84 Trans Am with some rust on the bottoms of the doors. I have found a cheap but rust free set of camaro doors, will they fit? No power options on either set of doors just basic set.
Matt
Matt
I just put An 84 camaro door on my Bird. The fit is great and the body line at the bottem matches. Can anyone tell me the best way to fill in ground\fx holes????
305TBI(LO3)
K&N filter
305TBI(LO3)
K&N filter
The BEST way to fill the holes is have a welder fill them in and then grind smooth. You could use the bondo method but you have to put some kind of backing (like fiberglass) behind the holes to act as an anchor. The welding should be very cheap to just fill in holes.
1992 Trans Am
05-10-2023 07:19 PM
I'llrocya
02-02-2016 11:43 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
