Painting rear passanger side? NEED HELP
Car rubbed against my car and left red streaks and little bumps. No major damage occured.
I was wondering what they best way to repaint this is?
If I wet-sand the area can I just paint it? I dont have to prime it unless I get down to metal?
Whats the best way to go about taking care of this problem? Help me out guys.
1987 Camaro LT 5.0 V8
If your going to drive a muscle car, put some muscle into it!
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you have little bumps, depending on how serious they are, you should spread a little bondo & sand it smooth. Or if they are real Minor you can use Filling primer & sand it smooth
You should definately sand & paint the area, IF when you are sanding you do not break into steel then I personally would not worry about primer.
If you do use Bondo then you will need to use primer anyway.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
John
G O D BLESS AMERICA
83 Camaro
83 T/A
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
