Anyone have pics of 6. or 8. rollbar installed?
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I'm looking to get an 8. rollbar so I can run a set of ET Streets out back. I'm undecided wether to get swing-outs, the kits that retain the factory arm rests, or to take the armrests out and use the straight bars for more room. The only thing I know for sure I want is the two bars going to the hatch that go over the rear seats keeping them semi-useful.
1986 T-Top Z-28, ZZ-4 Crate Engine, Complete High Flow TPIS TPI, SLP 1-3/4" Headers, 3" Exhaust, 3.73 gears, Moser Axles, Auburn Pro-Series Diff, 2800rpm 10" Non-Lockup Conv., 90/10 Front's, 40/60 Rears, Spohn LCA's, LCA's brackets, SSM SFC.
[This message has been edited by ryn28 (edited November 27, 2001).]
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I used the www.swracecars.com version with the side bars that clear the arm rests. I originally installed the 10 point cage, but when I painted the car last spring, I cut it back to an 8 point bar. Here is a link to a bunch of pics I took.
www.koolmeister.com/cage1.jpg thru cage9.jpg
Might have to C&P.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Might have to C&P.
Miles
www.koolmeister.com
I'm not a fan of swing outs. You're putting a cage in for maximum strength and safety. I feel swing outs compromise some of that. I haven't heard of anyone getting hurt because they had swing outs, but it just doesn't seem like a good idea.
