82 fiberglass hood
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
82 fiberglass hood
hello- i see fiberglass hoods that came stock from 82-84 i believe. how much do these weigh? to anybody that has one do you like it or would it be better to have a lift off. i'm going for weight savings.thanks craig
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
i picked one up in really rough shape at a junkyard for $25. I'm gonna cut out a lot of the extra support and pin it on my drag car. As is, it can't weigh more than like 40 - 50lbs. When i'm done, I'd say it'll weigh 30 or less with a lot of the support cut up.
i got a great deal, but it depends on how cheap you can get it.
Car: 86 camaro
thanks for the reply. could you tell me the width and length of the louvers that are on your hood? i was thinking of cutting them out and adding a scoop.
i have a crossfire hood on my car...i removed the louvers so the scoops feed the open element
it weighs maybe 25lbs
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
84z28HO
355
open element/k&n
10bolt w/3:42posi
performer intake
accel 8mm wires
160 stat
gta rims
gts blackouts
s.s panhard rod
"wonderbar"
4th gen z28 tips
14.3@95mph
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by craig:
thanks for the reply. could you tell me the width and length of the louvers that are on your hood? i was thinking of cutting them out and adding a scoop.</font>
if i think of it, next time i'm over there, i'll measure.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
