any way to make these clear agian?
Car: 1986 camaro iroc z
Axle/Gears: stock
i have lexan t tops and i want to make them clear but they got this masive rough film on it that ive tried to get off but it wont come off any ideas please help.
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Re: any way to make these clear agian?
Hello! Just did a quick search and this looks promising:
http://www.instructables.com/id/How-...er-4/?ALLSTEPS
Although, I'd also wait for a few more responses and compare them to find the right choice.
Good Luck!
Good Luck!
Axle/Gears: stock
i know most people will tell me to to get glass buti dont have money for that now if someone will just give me a set thats good
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
WET SAND! in several stages and Get a high speed buffer ($90) and a HEAVY CUT compound to start and work your way up to a finer polish.... IT's WORK!
Car: 1983 Z28
Engine: 385 Fastburn
You could go to the local autozone or advance auto and get a headlight cleaning kit, or a bottle of mcguire's headlight protectant for about 6 bucks and give it a shot. It should make a difference in the clarity, and might be enough to save you from having to put all the time and effort into doing a wet-sand job.
Axle/Gears: stock
i have one of them kits and it wont take this stuff off its al lrough and thick i sanded one side down and morel ight comes through but its not clear completely
replacement glass ttops are readily available at junk-yards and cost about $40/set or less. If it's not in your budget right now, it's probably worth saving up for them.
Jeff ~
Jeff ~
- Sand smooth as described above.
- Use rattle can enamel to cover (gloss black is always good.)
- Enjoy until t-top money flows your way.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I painted mine with SEMS trim black after sanding and am very happy with the results.
Check my build thread for pictures
Axle/Gears: stock
my grand dads probably gona buy me a set of glass ones for christmas but i just want her insured tagged and inspected so i can drive her
Axle/Gears: stock
not gona get rid of em till i get glass even then i might keep em and see what i can do
Car: camaro
Engine: 3.1
Transmission: auto
