How can I get this off the paint?!?
I've tried sanding it but It just melts. I've tried other things. What will just make it come right off? It's the color fade decal type thing from the beige to gold. Look at the signature.
1984 Firebird SE
1985 Camaro z28 305 engine T-5 Five Speed Tranny, 92 Camaro Leather Seats Console, carpet everything. Soon to put in 700R4 and 427CI. (Hopefully.
To view my car go to:
http://geocities.com/jmboriss/bluecar.html
It is for sale, asking $2000.
1984 Firebird SE
Heat it with a heatgun if you have one, or just a good hairdryer. The heat should melt the glue and allow you to peel it off. Just be careful and don't burn yourself.
3M also makes adhesive cleaner that, with a little elbow grease, will take away all the glue left behind.
1987 IROC,305 TPI Slush box G80,G92,143K+:Mint condition,K&N Filters, ADS Superchip, Stock Exhaust, Virgin Engine and transmission.
1968 SS Camaro, 350 built and shaved, Holley 750 Dual line double pumper, TH-400, 3.73's
Two other Thrid Gen Camaro's for parts ('84Z and '85Z TPI)
1 Post
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
3M makes a "Stripe Eraser" that attaches to a drill. Very easy and will not harm the paint below. For *** sakes, don't sand it! The eraser will also take the sanded parts off clean. When i took my '82's original stripes off in '94, i used a heat gun and it was a PITA. The stripes kept breaking off (brittle) plus the heat of the gun on the plastic (covers) is not good. I wish i knew of the eraser then. The front cover is especially hard with a heat gun because the stripe wants to tear at every little stone chip.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Kenney
GM junkie
Car: 85 Trans Am WS6
Engine: 305HO L69
where do they sell the stripe eraser?
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
Use a hair blow drier it will come right off. Go to PepBoys buy some bumper sticker remover clean the area of any leftover glue etc. also heard you could use WD40.
STEEL1212@AOL.COM
87' Camaro 2.8 Sport Coupe
www.thirdgen.org/rides/index.tgo?action=view&rideid=8023 .
STEEL1212@AOL.COM
1 Post
Car: 82 T/A WS7
Engine: Pontiac 400
3M Stripe eraser can be had at any auto body supply store or auto parts stores like NAPA.
It takes the glue off too, in a fraction of the time it takes using a heat gun.
Kenney
GM junkie
Kenney
GM junkie
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
