Factory bondo on roof is cracking bad and getting worst please help!
Car: 1988 Camaro
Engine: 350 CI Big Block
Transmission: TH350 Auto
Ok so I've been building this 88 base Camaro that I bought I noticed a tiny little crack in the paint a year ago, I thought it would be fine but now the whole roof is getting them and they're bad. Any advise on how to fix, bondo maybe? I've never used bondo...
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: Factory bondo on roof is cracking bad and getting worst please help!
Your description is pretty vague, but if it is in fact just the paint cracking, there's absolutely no need for bondo. Just sand down and repaint. Post up some pictures of the damage if you can.
Car: 1988 Camaro
ok so i took some pics i also popped a piece of the paint off to see if it was the factory bondo it is. problem is ive never used bondo so i dont know what to do next.
that doesnt look like bondo, it looks like the paint pulling up all the way to the metal. these cars had a recall a long time ago (clearly you're past the allotted time to send your car for the recall) where the primer wasnt sticking to the metal, so the paint was just popping off in sheets. like musclecar70fan said, only thing you can do is sand it all to bare metal, and paint it again.
Keep in mind: this is the roof of the car, it sees a lot of sunlight and is beaten up by it all the time. I can see where it looks like clearcoat or just the paint coming up (the blotchy colors)
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
That's not factory paint. Looks like super thick bondo cover up. I'll bet your roof was either hail damaged or badly surface rusted. I would pull your headliner and see what the backside looks like.
I think you are going to have a lot of work to do fixing someone's half assed cover up.
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
Also, as fare as I know there is no factory bondO...
Car: 1988 Camaro
well i know it has to be damaged because when i stick my finger in the spot that i peeled up the metal is dented in. I thought maybe at the factory when the car was made there was some imperfections in the metal so they kinda like bondo it. idk i've heard so many stories.
Car: 1988 Camaro
**** if it were a t-top i wouldnt have to worry about it lol
+1 on hail or some other damage repaired, and badly. Probably have it on the hood and hatch as well. When the paint issues happen that was mentioned earlier, it peels off in sheets to the primer.
Car: 1988 Camaro
yes the hood has it too but the hatch is fine, im putting a light weight fiberglass hood on anyway. so do i have to sand the entire car down to bare metal?
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Only where it needs it. If the rest of the paint is fine and not coming off like that there is no reason to do un-necessary work.
1 Post
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Is there frame ties on your car? Maybe a bit too much chassis flex causing the issues you're having?
Might want to look at the underside before you put too much work into removing the bondo. If it's not just little dents but a big dent like a tree fell on it , you might save time by knocking out the dent from beneath, the bondo will come off in big chunks.
Car: 92 RS Heritage
Yep. Additionally, for clarification, there never has been a recall on peeling paint for these cars. There was a Technical Service Bulletin in the late 80s/early 90s that covered most paint peelers, but there was never a recall.
From what I understand the factory DOES use some sort of filler in a few spots on the back half of the car. More of a seam filler though where they weld the roof/quarters together I think. But it's nowhere near that thick.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Bad body work and paint there. Not from the factory as stated.
Yes, the factory does use a small amount of seam sealer where the quarter meets the roof, but thats not what you are dealing with here.
That car needs to be striped to bare metal, and have a proper bodywork/paint job done.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I guess, they could try to tap the big ones from the inside, level them and then add filler but. A junk roof is usually a junk roof.
-- Joe
-- Joe
Car: 1971 Camaro
Engine: 427
If it is infact hail damage, those type dents can easily be
Car: 1971 Camaro
Engine: 427
Yep, I believe they use a brazing process. When I striped my iroc it had the copper line, heck even my 55 chevy had the copper colored line at the seams.
colton_carlson
03-08-2019 12:21 PM
