180 Speedo for Firebirds
Old 11-21-2001, 02:45 PM
  #51
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The dimentions of the original Speedo is (4 9/16" wide x 4 1/4" tall)that is the gage size NOT the image size because the Image might have a little white around the edges. The circle should be about (4 5/32" in DIA)
To resize the 180 speedo image to about perfect you have to resize the image to 42% of the original size
The 100 AND 150 Speedo I had to resize twice 44% was too big, 43% was too small. So resize to 44% then resize again to 99% to get it perfect.
Keep in mind that you take your original gage and lay it on top of your print, then you can see how well the holes line up to your original. I Traced the outside of the original on the computer, so you have to go from the INSIDE of the line.
HOPE that makes sence...
John
[This message has been edited by okfoz (edited November 21, 2001).]
Jorlain
08-24-2022 05:11 PM
Eric2ndGen
11-05-2015 01:51 PM
stickychinsac
08-31-2015 06:06 AM
IROCZDAVE (88-L98)
08-24-2015 06:54 AM
beachrodder
08-07-2015 04:27 PM
Quick Reply: 180 Speedo for Firebirds
