People with painted interior accents
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Dig it man, but does your tach get in your view? Mine is on the left, and it still gets in the way.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Why do you need 2 tachs?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
1983 Firebird
TH700R4 Auto
Small Block 400
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The dash tack has a shift light, I can only assume that he uses it to shift at the right time.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
John
G O D BLESS AMERICA
83 Camaro
83 T/A
Yea...I had fuzzy dice hanging in my rearview window for about 30 min and then took them down cause i couldent see anyhting. I would imagine that tach takes away like 90 % of your vision
Red 89 Trans AM GTA
T- tops
Engine stroked to 383ci
World Products heads
Elgin cam
GM 5.7 rods
Keith Black pistons
2-row timing chain
Mellins Hi-Volume oil pump
9:1 compression
24# Ford Fuel Injectors
Edelbrock TES Headers
hi-flow Catalytic Conv
SLP Stainless Steel Cat-back exhaust system
Torkmaster Torque Converter (2000 stall).
Red 89 Trans AM GTA
T- tops
Elgin cam
GM 5.7 rods
Keith Black pistons
2-row timing chain
9:1 compression
if you thikn its hard to drive with a tach in your was, try an almost 5 inch cowl hood., when i mount my tack its going to be were i can see anything, but not in the way of my fuel pressure gauge that is in the cowl. and like the last person said, i drive a megashifter and 85% of the time im shifting ti myself
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Those all look really good, any special prep and paint to keep them from peeling?
Basset, is that a Lumina Z steering wheel? It looks really good in your car. I never much cared for those pre-airbag stock Camaro wheels.
Car: 91 Firebird Vert
Engine: LO3
<font face="Verdana, Arial" size="2">Originally posted by PhantomChamp:
Basset, is that a Lumina Z steering wheel? It looks really good in your car. I never much cared for those pre-airbag stock Camaro wheels.</font>
ambainb
04-25-2016 09:21 PM
