84 Trans am hood to cowl weatherstrip
Mine was removed when it was repainted before I bought it so I just bought a new one to put in. I'm assuming it goes on the cowl as opposed to attaching to the hood, right? There are holes in the weatherstrip like it should be clipped on or screwed on but I don't see any holes for them to get clipped into. Does the 84 just get glued on with weatherstrip adhesive? Also, the weatherstrip is kind of "C" shaped to give you access to the holes I mentioned so when it's installed does it matter which direction the opening faces? Any help would be great. Thanks!
Ben
Ben
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: 84 Trans am hood to cowl weatherstrip
I'm pretty sure it attaches to the underside of the hood. You'll see a ridge running along the rear edge of the hood with holes in it. It matches the contours of the cowl.
Never thought of checking the hood. Other old cars I had had it attached to the cowl. Hopefully it's not there or else I'll be selling a new hood to cowl seal on the site. Thanks for the info!
Ben
Ben
Yes, the hoods are fairly unique on these cars. Most cars, old and new, have the seal on the cowl.
1992 Trans Am
05-10-2023 07:19 PM
Street Lethal
04-30-2019 12:14 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
ElPaleterro85
08-13-2015 03:49 PM
3rdgenparts
08-06-2015 09:03 AM
