Aftermarket door panels?
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
I am still in dire need of door panels and am getting somewhat desperate. Its been two months since i started redoing the interior and when i pulled my old door panels off to redo them in vinyl they fell apart. Ive scoured through classifieds and cant find a thing, so im wondering if there is anywhere i can score some new door panels, other then year one? Ive seen some clean door panels with what looks like an embroidered flame about the arm rest, boy was that nice, thats something i have in mind. any help would be appreciated.
1987 LG4 Camaro z28
Modifications- Flowmaster 80 series, KN airfilter, high flow cat, 180* stat, edelbrock performer intake manifold, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
1987 LG4 Camaro z28
I think I ran across a pair of GTA door panels on ebay either yesterday or today... just do a search for 92 GTA and they should pop up in there somewhere.
They are a molded door panel rather than that cheap press cardboard that the original base ones were made of.
Good luck
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Good luck
Carl
CarAudio Resources
Engine: LB9
Axle/Gears: 3:43
When i typed in 92 GTA i came across two seperate auctions for door panels, one for driver side and the other for passenger side. I bid on both, now im just wondering how difficult it would be to chop up in order to get my trim panels to fit those panels.
If they're the ones that I'm seeing on there now for drivers and pass panels, they aren't the right ones.
The good GTA panels have a raised section where the arm rest sits rather than completely flat.
The ones I saw may be over, but I'll go search again.
edit: Okay, I just did my normal searches and it appears the ones I was talking about are over. The only ones on there now are the normal flat ones like you already have.
[This message has been edited by GndPrx (edited November 17, 2001).]
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
