Formula 350 questions
do al the formula 350's have the w62 RPO code? Im went to buy a front air amn for my car and it doesnt fit so Im wondering If I have the one for models without the w62
1 Post
Car: 1984 Trans Am
Engine: GMPP 350 V8
W62 is the RPO for the AeroPackage, better known as Ground effects. No Formula ever had Ground effects as a factory item. In fact the whole idea of the Formula was to NOT have the GFX. So yes I think you have the wrong part. RPO sheets can be in-accurate sometimes. Your car does not have W62, the airdam should be the same as all Formula's and Firebirds (w/o gfx).
1983 TransAm
1984 TransAm
1994 TransAm GT
1994 25th TransAm GT
1990 T-Bird SC
1971 Boss 351
Four TransAm's are not enough. Firebirds for all.
1983 TransAm
1984 TransAm
1994 TransAm GT
1990 T-Bird SC
1971 Boss 351
I didnt think I did have the w62 because I was fairly sure it was the transam. I got the air dman for the non-w62 car but it still wont work. the wholes dont even line up. NOT EVEN CLOSE!
1 Post
Car: 1984 Trans Am
Engine: GMPP 350 V8
Hmm, Im sure somebody can figure out what the problem is, fortunetly I havent had to replace my Airdams
On another note: I just noticed your user name OldBlue, my 84's nickname is Ol'Blue
I used a air dam from a 83 T/A on my 89 Camaro and it worked perfect. Take measurements of where your holes are and hit the junk yard. No sense in paying for a new one from the factory.
'89 Chevy Camaro
305 TBI
COMPLETELY stock
'89 Chevy Camaro
305 TBI
COMPLETELY stock
its actually not that expensive from the factory only 26.04. But then again the only reason I went to a deal was because I couldnt find any at the junk yards hehehe
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I put a new air dam on my car when I first got it awhile back. Thanks to the previous owner ripping it off and bending the frame in a wreck *fume*.... anyways when my dad ordered mine it didn't look the same and a few of the holes didn't bolt up either. But I made it work. I think I ended up just drilling some new holes for on the air dam itself to make one side line up. The other side I believe I was able to get it to line up without any mods. It's stayed on for 1 1/2 years now being rubbed a lot.
1 Post
Car: 1990 Formula
Engine: 5.7 liter
go to my site below....
click below to check out the new Formula Source....
www.theformulasource.com
or click below to check out my Formula350.......
www.formula350.com
or click below to email me
webmaster@theformulasource.com
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
www.formula350.com
