problem locks
problem locks
Want to use my unlock panel but the lock on the passenger side does not go all the way so my door is still lock
what do i have to do to fix that?
The lock mechanisms inside the door probably need lubricated. Pull off the inside door panel. Work the lock back and forth to identify all the parts that move. (Clean and) Lubricate all the movement points. You should also probably lubricate the door window hardware while you're in there. Put it all back together and you should be good for a couple years.
He is right. I had the same prob last year. Cleaned and white lithiumed everything. Works fine now. Make sure to do the window mechanisms. Might as well while its torn apart.
'89 Chevy Camaro
305 TBI
COMPLETELY stock
'89 Chevy Camaro
305 TBI
COMPLETELY stock
someone972
08-30-2015 12:52 AM
