T-Tops stuck in lock position
Car: 1992 Camaro
Engine: 350 miniram
I picked up a pair of t-tops but the only problem is that they are in the locked position and I don't have the key to unlock them. Is there any way I can get them into the unlock position without destroying the lock mechanism?
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It may be possible to remove the plastic panel on the underside of the T-top and mess with the mechanism. It might take a little ingunuity, but I believe it is possible.
John
John
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
