Overhead Console Install...How Hard??
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Hey guys I was just wondering if all thirdgens came with the holes to mount an overhead console. Reason I ask if because im selling an overhead console with the screws and mounting pegs and someone wants to know if he could install it into his car without the console. Would he need a template or can he just put the pegs and screws in and go?
took me 1.5 hours and that was taking my time
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
http://www.geocities.com/toosloz/84camaroz28.html
84z28HO
355
open element/k&n
10bolt w/3:42posi
performer intake
accel 8mm wires
160 stat
gta rims
gts blackouts
s.s panhard rod
"wonderbar"
4th gen z28 tips
There is a tech artical on this if you haven't all ready read that. I believe it says to pull your headliner. I have heard of people pulling the stock light, mounting the console to the rear mounts, holding it up and marking the front mounts. I can't possibly see it being that hard, just tell him to take his time to keep from screwing up the headliner.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
my 87 Formula, had the holes, and my 83 Trans Am had the holes too, so I assume from 83 thru 87 is a definate YES on the holes... I have talked to folks with later cars who have done it as well and they all had holes, but this is not personally confirmed...
John
John
1 Post
Car: 92 Formula
Transmission: A4
They all do.
Check out my website....
I have the instructions for installing it into my non-t-top 92 RS.
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
What are you planning to put in this overhead console¿
>mabe some *****
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
>mabe some *****
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Breazlan
09-25-2015 11:20 AM
