Cruise/Wiper/Turn Signal shaft replacement
1 Post
Car: 1986 IROC-Z
The paint labeling on this "shaft" is worn away and I am looking into replacing it. How much would one cost, and how easy is it to replace it?
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI
B&M Megashifter
Grant GT Steering Wheel
New A/C Motor!
View my website, a work-in-progress
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
New A/C Motor!
i want to replace my stock column with a newer one that has tilt. i also want something like on the new vehicles where ya open the door the area around the ignition lights up i got no idea how to do that. its just another fantisy. i think you can get them cheep from a wrecker. you just got to know your column lenghth and your spline type/lenght. i think...
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Hey Tyler, he is not talking about the steering column, but the turn signal switch.
Sorry, I do not know how to do it, but want to do it too.
Car: 89 formula
Transmission: t5, soon to be t56
sorry to say...but that little stick has to have the whole steering column taken appart...when i bought my car the guy who had it before me snapped it off...so i made them replace it...i watched the dealership do it...i suggest you take it to a chevy dealer..its safer..plus if they get it wrong you can take it back and complain
Snuffit
edit: cant spell
[This message has been edited by Snuffit (edited September 23, 2001).]
Snuffit
edit: cant spell
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
You will have to get the shaft itself from a dealer, or maybe somewhere like classic industries. It's not much harder to replace the blinker shaft than it is to replace the key lock cylinder for the ignition. Look around the board and you should be able to find info from someone who has done it already. If you can find an exploded view of the steering column it will help also. Sometimes you can get one printed up for you at a dealer.
Car: 92 Firebird
Engine: 3.1L V6
I snapped mine off...
i can't use my wiper blades, so far it's not a problem but it will start raining pretty soon around here...
i was hopeing i could do it myself but i'm not so sure if i trust myself to take apart the whole damn column, especcially with an airbag...
but would it be a challenge for me to do it myself or just impossible.
and how much would a place charge to replace it for me...
[This message has been edited by Blaze of Glory (edited September 23, 2001).]
I believe that the lever just pulls out. You'll have to disconect the cruise cable, and pull it through, along with a piece of wire or string so that you can put it back. It sounds to me like everybody who had to take their column apart had to do so because the piece that had broken off was too far in to get out easily. The only other thing is I think in the NextGeneration magazine they have these things for like $50.
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Can someone just make a sticker or somethin that you can put on top of the worn lettering?? I have that and I don't know how to turn on the cruise because its all black.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
<font face="Verdana, Arial" size="2">Originally posted by Snuffit:
Snuffit
edit: cant spell
</font>
Snuffit
edit: cant spell
</font>
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1 Post
Car: 1986 IROC-Z
So it just pulls right out? I'll have to try that. Thanks, all.
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
New A/C Motor!
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
New A/C Motor!
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
figure about $120 from a dealer or around $80 from a non-dealer place that carries GM parts.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
G O D BLESS AMERICA
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
1 Post
Car: 1986 IROC-Z
I just tried to pull the lever out, but it won't budge. Is there a screw or something inside the column that needs to be removed first?
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
New A/C Motor!
1986 Camaro IROC-Z
305 TPI
B&M Megashifter
New A/C Motor!
Axle/Gears: Drums?
There should be a screw holding the actual shaft on the steering column, but you will have to pull the wheel and the spring tensioner to get to it. Once you remove the screw it should pull right out.
91 305 TA Convertible
79 Camaro Z-28 (Hibernating)
If speed kills I would've been dead a long time ago.
Well, both in my 91 bird, and 89 camaro, I just tugged on them and they pulled out. It'll be a little stiff. Of course I wouldn't want to misinform you and have you break it, better to err on the side of caution, but the Chilton's manual says just pull too, so.....you decide.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I got mine with cruise for $80 from www.gmpartsdirect.com
I gave it a yank straight out and it popped out of the socket. Since i had cruise, i did have to take the column apart so i could feed the cruise wire to the plug at the base of the column.
[This message has been edited by Justins86bird (edited September 27, 2001).]
1 Post
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Year One sells them for around $50. Don't have my catalogue in front of me but I am planning on changing mine in the near future as it came bent when I bought the car.
Fronzizzle
03-18-2019 08:29 PM
