How do I remove the front turn signles?
Alright you know the front turn signles on the Camaro, I want to open that up, but I can't get the piece of plastic to come off. Cuase I want to install this set of blue strobe lights I bought off ebay behind there. ANyone know how I pop those covers off?
Car: 1986 IROC-Z
Engine: 5.0 TPI
I can tell you how to get the assembly out, if that's what your asking. I found the easiest way is to remove or just drop the front of the air dam. Look up in there, and you should be able to see the two 10mm bolts holding each one in.
