T-Tops corrosion
T-Tops corrosion
My '87 Camaro T-Tops leak in several areas. Before I apply a sealant as I see some have recommended, what should I use to fill in the rust corrosion? Is there a seal or channel that I need to make sure I don't block when adding sealant? I then plan to add a new headliner with new fiberglass for about $250.
Sealants are good for a low-buck solution, but if you're going to get a new headliner and all, I would get new weatherstripping. Sealers aren't always enough, and I'd hate to ruin the new headliner.
![](https://www.thirdgen.org/messgboard/smile.gif)
Anybody have advice on working on the corrosion on the top of the car where the T-top sits.I have been thrown some names such as Ospho, poxy, and seam sealer. Any metal repair experts have advice or suggestions where I can read up on this??
[This message has been edited by Cityboy (edited September 27, 2001).]
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
