Pop Mech. On Power Hatch
Old 08-26-2001 | 05:43 PM
Tyler-88's Avatar
my 88 camaro has a power motor to control the hatch. i was wondering how i would go about putting in a button to pop the hatch from the drivers seat. is it possible?
Old 08-26-2001 | 05:58 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
The power hatch release was an option in 90-92 so it should be possible. You would probably have to look at one and see how it's wired.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old 08-26-2001 | 06:30 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Camaro's don't have the power hatch release?? HEH Learn somethin new everyday!
BTW, if you didn't know, I think all the Firebirds w/ the electric hatch have it, (don't quote me though) maybe you can look @ a junkyard firebird.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old 08-26-2001 | 10:19 PM
Tyler-88's Avatar
89V6FBIRD
hrmm, i wouldnt think i could just toss on some wires, the only way to open the hatch is to use a key and that inturn turns something that pops the hatch open and than the hatch motor comes up. excuse me for the lack of knowledge and terms. junk yards around here dont like to carry and F-Body anythings. oh well, i'll keep looking i guess.
Old 08-26-2001 | 10:53 PM
89V6FBIRD's Avatar
that's a shame, there are sooooo many f-bodies in the local junk yards here in the L.A. area. Well at least you don't have to look at the sight of all those deceased f-bodies
Old 08-27-2001 | 02:14 AM
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by 89V6FBIRD:
</font>
Hell yeah...there are boatloads of thirdgens around here. Do you go to the ones in Sunland??
Tyler, you might want to try to dig up some info on hatch motors. Maybe the ones with release switches are different from the non-switch ones. But...if they are the same there should be a way to rig the switch. Try a parts store and see if they ask "with or w/out power switch".
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old 08-27-2001 | 10:55 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
From what I have found the latch mechs are pretty much the same. The biggest difference between latches is how they mount to the chasis. ALL you need is a power release, there is only one bolt holding it on. I have taken non-power release hatches from the junk yard and installed the power release latch I had on them. If I remember correctly I installed a power release solinoid from a 83 T/A on a 92 Firebird hatch mech.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old 08-27-2001 | 10:58 AM
Drew's Avatar
Every Camaro/Firebird from 1986-92 has the power pulldown, not all of them have the electic release. Check my artical in the tech section for exact info. It should be pretty close to identical for your car. You might not have the wiring, and the artical is directed towards 90-92 Firebirds.
Old 08-27-2001 | 07:21 PM
irocbod's Avatar
Hey guys if all your talking about is doing it from the drivers seat my 88 Iroc has is. The switch just pulls back, it's between the window switches on the console. Make sure that if you rig one up that you can't open it while in gear.
Old 08-28-2001 | 01:23 AM
89V6FBIRD's Avatar
</font>
That's a good point. The switch only works if the ignition is off, or if its on, the parking break is set. Oh yea, Cali, I do go to the sunland ones, it just depressed me the last time I went. (Maybe because I didn't find anything I wanted)
[This message has been edited by 89V6FBIRD (edited August 28, 2001).]
Old 08-28-2001 | 04:22 AM
irocbod's Avatar
Hey guys in Los Angeles area are there any good clubs around. I've gone to some of the sun valley recker yards and there just too big of a pain to get any good parts. The sensor for my switch went bad and while driving down the 210 I bumped it, both windows down. Lost every light inside that wasn't bolted down and almoast lost the hatch. :-( . Good luck trying to rig one.
Old 08-28-2001 | 10:52 AM
89FirebirdUK's Avatar
I have a 89 firebird, which didn't have the power hatch release. The parts I needed were:
1) Release button to fit in console
2) Relay which plugs into some wiring behind the console
3) Hatch release solenoid
4) Another relay which controls the pulldown mechanism
All the other bits were present in the car.
Unfortunately the wiring that controls the pulldown mechanism is tied into my alarm system. When I added the relay to the pulldown wiring this made my alarm think the hatch was always open !
Old 08-28-2001 | 11:00 AM
Blown_n_Injected's Avatar
Camaro's have em too...My 87 IROC has the release between the P-window switches. My 92 T/A Has it on the dash above the radio.
There is no substitution for cubic inches!
Old 09-15-2001 | 03:34 PM
Tyler-88's Avatar
a guy i was talking to recomended an actuator. i think thats how its spelt. same thing im using for my keyless entry...
Vintageracer
01-10-2020 06:33 PM
sailtexas186548
08-24-2015 11:11 PM
zayne0
08-24-2015 08:22 PM
stalkier
08-13-2015 01:59 PM
Randomtask2
08-13-2015 02:57 AM
