rear wing removal - help
I'm planning some paint work on my Formula this month. Can anyone provide me info on the removal of the rear wing on the '87-'90 Formulas. Mine is rusting inside on the left front clip. Can this clip be replaced?
Please advise.
Thanks!
1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR,
FLOWMASTER AMERICAN
THUNDER CAT-BACK
http://members.fbody.com/tomahawk350/
Please advise.
Thanks!
FLOWMASTER AMERICAN
THUNDER CAT-BACK
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
to take the wing off, open and raise the hatch, if you look at the bottom of the hatch, there are i think 6 bolts, maybe a few more, unbolt them they are the bolts that hold the wing to the hatch. then after those are out, if you have a 3rd brake light, you will have to disconect it, then close the hatch, and push the wing towards the front of the car, there are 3 slide type clips on each side, sliding it forward "unlocks" them and then you can take the wing off. i just did this on my car, i ended up sanding the whole thing down to the rubber with a D/A sander with 150 grit. hope this helps. lil jay
Wide Open Till You See *** ...Then Brake
[This message has been edited by LilJayV10 (edited September 11, 2001).]
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
On mine the clips were badly rusted (which was why the spoiler bulged) and I wasn't able to slide the spoiler forward, and when I forced it, I wound up pulling most of the clips out of the spoiler. I didn't care because I was junking the spoiler, but you may want to spray a healthy dose of Liquid Wrench on them and take it easy if you plan on reusing the spoiler.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
