Where to buy Acorn nuts for Door Ground FX on 92 camaro
The title says it all.... I've been all over town trying to track the things down. I'm reluctant to just buy them online because with these self-tapping nuts it's hard to determine the proper size.
Any links would be really appreciated.
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Re: Where to buy Acorn nuts for Door Ground FX on 92 camaro
They are called acorn push nuts. I googled it and a few different suppliers came up. Ineed to get some myself. I was just looking the other day for some.
Fair enough.... does anybody know the size?
I mean I can get the size of the nut in terms of what size wrench turns it, but would there be different sized holes?
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
All the ones I got off where a 13mm and I might have a few kicking around here somewhere if you want me to look
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Try www.mcmaster.com for anything hardware related.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/245..._p/pas8145.htm
http://www.clipsandfasteners.com/,they have anything you need.
http://www.clipsandfasteners.com/Nut...corn_s/117.htm
Car: 1988 Camaro IROC Z-28
Engine: 5.7L
Transmission: Automatic
Go to McMaster-Carr, I use that place for work and home and they are outstanding! You don't want an acorn nut because those are threaded, you want a push nut...See link below.
http://www.mcmaster.com/#push-nuts/=nl9zfj
Car: 1988 IROC-Z
I did some digging and I believe the part number is 11501047. Description says "NUT, Met Skw (M5x15) Flg Phos (Part of 6)". Looks like I found something on the following website but it is not clear if this is the right part. Worth a call...
http://www.newgmparts.com/parts/1988...icleid=1035661
Let us know how it goes and what solution you come up with. I am fast approaching the need to get some myself.
-CB
-CB
Those links are appreciated, but with the exception of gm link, none of those are correct. Still iffy on the gm one though because it doesn't have a pic.
It isn't a push nut, it isn't an acorn nut, it's an acorn push nut. thus why I've been having such a hard time. The size of the nut (not the hole) is 11mm you can't use regular old push nuts because in the front part of the fx at least the shaft you screw it onto is right against the door, so there isn't room. I've tried fitting a few push nuts they have at the hardware store and there just isn't enough room.
This particular size seems nearly impossible to find new. There are various ebay auctions where people are selling the nuts off of their car, but those are old and rusty... not sure how long they would last. I'm running out of ideas.
Engine: 5.0 EFI
Did you check with your local GM Dealer or your local auto Paint Supply co.????
Engine: 5.0 EFI
I haven't checked with the dealer yet, mostly because I would probably have to take the car down and atm I've got the inside of the door off.
manta that's not an acron nut like you linked to, we are looking for an acron push nut. You should be able to tell by the very pic you posted.
Engine: 5.0 EFI
http://www.newgmparts.com/parts/1988...ODY%20HARDWARE
That Acorn nut on my car (TA) in the pic is P/N 20561698 and the site above list it,but it doesn't describe what it is
Car: 1988 IROC-Z
Found this website:
http://oemcats.com/oem-parts/20561698.html
The description seems like it is the right part...
Engine: 5.0 EFI
Found this website:
92firebirdchris
Exterior Parts for Sale
08-14-2015 12:56 PM
