My rear has a crack in it .
Not my rear My car ! I have a 88 rs with the plastic bumper .I guess it's plastic , like a hard plastic .Well it has a crack in it and I want to replace it . I just need the outer part of the bumper , you know how the bumper has several layers .Well , Has anyone replaced this ? How hard is it ? How much do you think a bumper well cost from the junkyard ? Thanx in advance guys , Wayne
That'll probably vary from region to region so make a couple of calls to boneyards and ask around. You could also (depending on the size of your crack ) use an epoxy to fill it, sand it, then repaint.
Steve
Steve's Trans Am Temple
Steve
Thanks brother, the nostrils are cut out and I have an open element sitting behind it currently. I'm working on a tray/pan type of thing to block off the element from hot engine air, but it works okay so far!
Steve
Steve
