LOF vs PPG Windshields. Same ?
Old 09-06-2001 | 01:01 PM
GTA88's Avatar
The windshield place that is going to install my windshield says that PPG and LOF are BOTH oem on a Trans Am. Is that true ? I read somewhere that PPG was the oem and lof was not. With any luck I won't get locked here by the moderators. The windshield guy is coming out tomorrow and I need to know which glass is better. The windshield place said they were both 'very good' and both oem.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old 09-06-2001 | 01:36 PM
custman87T/A's Avatar
Both my 87 and my 86 parts car have PPG all around. Hope that helps ya
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old 09-06-2001 | 01:48 PM
GTA88's Avatar
I suppose I'm wondering if it makes any difference if I get PPG instead of LOF.
Old 09-06-2001 | 02:46 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You probably would not noice the difference.
Never herd of LOF.
I know Guardian makes windshields too.
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old 09-06-2001 | 04:00 PM
Blue502's Avatar
Both my 86 Camaro and my 88 IROC are LOF all the way around with the exception of the t-tops on my 86 which are PPG. The glass in my 86 is all original, not certain about the 88 (can't remember how to read the date codes off the top of my head). LOF stands for Libby Owen Ford and is original equipment on GM cars way, way back.
IROCnRoll
'86 Camaro Sport Coupe and '88 IROC
Old 09-06-2001 | 11:27 PM
m3baller's Avatar
car has ppg all around.
Old 09-07-2001 | 07:49 PM
89convertIROCer's Avatar
Engine: TPI
Both PPG & LOF are OEM (Original Equipment Manufacturer). GM always has multiple suppliers for assembly line parts. Every single part. How stupid would it be to rely on one supplier for a part? A supply problem would shut down the assembly line.
Steve
1989 IROC Convertible
22 Option "Daily Driver"
Hawk312
08-22-2017 09:55 PM
FrankieRider2
09-24-2005 06:28 PM
3rdgenstm
03-06-2005 08:58 PM
GTA88
09-06-2001 01:35 PM
